24.04.5 to 26.04.1
Hi all! I’ve been using Ubuntu Budgie since 2022, starting with 22.04 on my desktop and then my laptops, and I’ve loved the journey. The 22.04 → 24.04 jump had a few bumps we worked through together, and now I’m back for 26.04! When the upgrade prompt appeared, I went for it and spent a few days working through the teething problems across three machines (a desktop and two laptops). I’ve solved nearly everything; just two issues remain that I couldn’t find a good solution for:
  1. Budgie Menu keyboard focus: typing after pressing Super goes to the previous window. I understand this is fixed in Budgie 10.10.3. Is there a rough plan for getting 10.10.3 to 26.04, as a regular update or through the backports PPA?
  2. Software KVM: on 24.04 I shared one keyboard and mouse across all three machines with Input Leap. On 26.04, Input Leap and Deskflow (tested 1.27.0) can’t run as the server because labwc has no InputCapture portal. Lan Mouse gets very close using layer-shell, but labwc doesn’t hold the pointer lock. This is tracked in Lan Mouse capture released: layer-shell pointer lock not held · Issue #3745 · labwc/labwc · GitHub , where I’ve confirmed it on Ubuntu Budgie 26.04 with my own logs. If labwc fixes this, would the team consider shipping a newer or patched labwc for 26.04 via backports? And is InputCapture portal support for labwc on the roadmap at all?
I am also open to other suggestions or ideas for how to address the two concerns above too if others have found good solutions.
Setup: Ubuntu Budgie 26.04.1, Budgie 10.10.2, labwc 0.9.3, AMD RX 6700 XT, two monitors. Two laptops also running Ubuntu 26.04.1. Happy to test anything. Thanks for all your work on the Wayland transition! <3
So yes - once UB 27.04 hits the streets next April, the aim is to get this into our backports-budgie PPA. It is already in our wayland-test PPA (treat this as unstable) - Budgie Panel fails to expand to full width on Primary Monitor in Wayland (Labwc) - #2 by fossfreedom
You’ll see that we’ve backports labwc in the PPA above.
From the links you provided - I don’t see any current movement on this by labwc upstream.
In terms of 26.04 - and assuming gemini’s AI isn’t hallucinating … wayfire has a plugin called shortcuts-inhibit which you can enable in your wayfire.ini - this apparently supports the keyboard-shortcut-inhibit-unstable-v1 protocol that input leap requires.
Spoiler alert - as part of the 26.10 release notes available sometime this week I’ll be showing how to run budgie on wayfire … and this is backported to 26.04 as well.
Thank you for your responses!
Quick update on both items:
  1. Budgie Menu focus: thanks for the timeline on 10.10.3. In the meantime I’ve put fuzzel on the Super key (themed to match and anchored under the top bar), which works well as a stopgap. I’ll switch back to Budgie Menu once 10.10.3 reaches backports.
  2. Software KVM: good news! A labwc contributor posted a patch on Lan Mouse capture released: layer-shell pointer lock not held · Issue #3745 · labwc/labwc · GitHub that lets layer-shell surfaces hold pointer constraints. It didn’t apply to 0.9.3 directly, so I ported it by hand (only the server-> / seat >server-> naming differs), built labwc 0.9.3 from the Ubuntu source package, and tested it: Lan Mouse capture now holds properly in all directions. Results and the diff are posted on the issue.
Once it’s merged upstream, would you consider including it in your labwc backport? It would give Ubuntu Budgie a working software KVM on labwc.
Happy to test a build from the wayland-test PPA whenever that’s useful.
Nicely done with that patch refactoring! Just the type of skill the UB team are really interested in :slight_smile:
The criteria for backports-budgie is straightforward - backport what has just been marked as stable with the very latest release.
So if the new version if labwc arrives from Debian into Ubuntu with the patch we will include it in our backports.
If you guys are interested in getting more help in testing, or where needed, let me know!
Hi FossFreedom,
Thank you for the list. I’ll take a look and cross reference it. Feel free to ignore the below but just in case I am including my full notes set. Just to be transparent with a note on how I work: I use AI as an assistant for notes and tracking changes. I used to document by hand everything it took to get from a fresh install to a setup I’m 100% happy with. Now I use AI plus tools (SaveDesktop and a pair of backup/restore scripts) to turn what was about an hour of setup into about 5 minutes. It also makes it much easier to track every bug I find, the workarounds, and the changes I made along the way, which is how this list came together. This approach has enabled me to track changes and bugs much better.
I don’t let it run my system or my code. It suggests things, and I review and run each change myself. Everything below was tested by hand on my machines.
Here’s my full set of notes from moving three machines to Ubuntu Budgie 26.04 (Budgie 10.10.2, labwc 0.9.3): a desktop with two monitors (Aerodin, AMD) and two laptops (OneThree, SevenSix). Each item has what I hit, what I did about it, and where it might help as a default.
I found workarounds for these issues so I only posted the two remaining and harder to fix issues. If any of these look of interest I’d be more than happy to post a Github bug issue/feature request for any of these items in the relevant Github project locations. My old habit of not calling for help unless I run into a brick wall or dead end after trying everything kind of stuck around.
Bugs
1. Budgie panel auto-hide (bottom panel, Dock mode)
  • Budgie Desktop Settings → Panels → bottom panel → Automatically hide:
    • Intelligent: the panel hides, but moving the mouse to the bottom edge never brings it back.
    • Automatic: the panel comes back, but its space stays reserved, so maximized windows stop short of the bottom of the screen.
  • Crystal Dock’s auto-hide works correctly in the same session, so this looks like a Budgie panel issue, not labwc in general. I moved to Crystal Dock and can retest on 10.10.3.
2. Budgie Menu doesn’t take keyboard input
  • Typing into the menu search does nothing; keyboard focus stays on the window behind it.
  • I know 10.10.3 fixes this. Until then, I’m using fuzzel on Super (<keybind key="Super_L" onRelease="yes"> plus gsettings set org.gnome.mutter overlay-key ''), themed to match QogirBudgie-Dark.
3. Trash applet crashes the panel
  • Adding the Trash applet takes the whole panel down. I worked around it by adding Trash as a dock launcher. This got streamlined to just going to Files recently instead.
4. Two monitors at login (SDDM mirrors the screens)
  • budgie-sddm-display-setup mirrors all outputs, so the greeter is mirrored across both monitors.
  • My fix: /etc/sddm/Xsetup places them side by side with xrandr, enabled through /etc/sddm.conf.d/90-xsetup.conf ([X11] DisplayCommand=). A 10- file didn’t work because 50-ubuntu-budgie.conf overrides it.
  • This ties into roadmap item #5 (SDDM + Cage multi-monitor). An “extend” option would cover it.
5. Black or mirrored screens after login, and 144 Hz going black
  • After login, my second monitor stayed black or mirrored until I added a kanshi profile (DP-1 2560x1440@143.999Hz plus DP-3 to its right) and started kanshi from autostart.
  • Picking 144 Hz in the display settings blanked the screen; the exact 143.999Hz mode in kanshi works.
6. Brightness-up key does nothing on one laptop (SevenSix)
  • budgie-brightness-helper --up has no effect there. brightnessctl -d acpi_video0 set +1 works once the user is in the video group. Brightness-down and the keyboard backlight work fine.
7. Window screenshot does nothing
  • Area screenshot (Ctrl+Print) works. The window-screenshot shortcut does nothing on labwc.
8. Power settings: what the GUI shows vs. what actually happens
  • One laptop (the only fresh Ubuntu Budgie 26.04 install => It’s the SevenSix [System 76] laptop from earlier) kept dimming and locking even with the GUI set not to. Setting the gsettings keys directly fixed it (idle-dim, ambient-enabled, idle-activation-enabled, idle-delay=0, sleep types ‘nothing’).
9. Lock screen (swaylock) was black
  • There’s no default swaylock config, so the lock screen showed a black background with a circle.
  • Wallpaper paths with spaces (%20 in the picture-uri) also don’t carry over. I copied the image to a path without spaces and wrote ~/.config/swaylock/config (image, scaling=fill, indicator settings).
    Strongly recommend changing the default as from a UI perspective I almost thought my machine had shutdown/powered off instead of locking as expected. Only when typing does it become apparent that I’m at a lock screen. Having a background and at least an idle typing indicator would prevent anyone from thinking their lock screen is broken.
10. Login screen (ubuntu-budgie-login theme)
  • An unquoted background path containing a space gives a black login screen; quoting the path fixes it.
  • To hide the avatar, setting avatar-active-size=0 is ignored because Config.qml falls back with || 120; a value of 1 works.
  • This ties into roadmap item #9 (slickSDDM): quoting paths, an option to hide the avatar, and pulling the wallpaper from the user’s background setting would cover it.
11. Clipboard from Wayland apps to XWayland/Proton apps (EVE Online)
  • Copying in Wayland apps doesn’t reliably reach XWayland games under Proton.
  • My fix: wl-paste --watch xclip -selection clipboard, started from autostart after a short delay. It has to run without the IBus variables (XMODIFIERS, QT_IM_MODULE), plus DESKTOP_AUTOSTART_ID, SESSION_MANAGER and GIO_LAUNCHED_*, or Ctrl+C breaks. I start it with env -u .... A systemd user service didn’t start in a Budgie session; autostart did.
    This approach will apply to any Steam game running via Proton Experimental (or earlier versions) which runs under Wayland as expected but without copy and paste ability. The user may not know Linux well and might have trouble figuring out where the actual trouble lies - they may assume it’s the game or Steam itself instead of a XWayland vs Wayland issue.
12. Release upgrade from 24.04 to 26.04
  • The upgrader disabled third-party repos (renamed them .disabled or commented them out). On one laptop, failed attempts deleted ubuntu.sources twice; with the System76 packages in the way, I ended up doing a clean install. This may not be a desired path for most users who are migrating with applications and files in place.
  • After upgrading, two machines (both migrating from 24.04 to 26.04) booted to a console. (They took the actual Ubuntu 24.04 => Ubuntu 26.04 upgrade paths so as expected ubuntu budgie desktop was not included). Installing ubuntu-budgie-desktop, budgie-desktop-environment and sddm and resetting the panel fixed them.
13. hardinfo2 crashes under Wayland
  • It disconnects about 75% of the time from Wayland on start when doing a big and full system inspection to store the system specs to disk. It works 100% with env GDK_BACKEND=x11 hardinfo2.
14. Software KVM (one keyboard and mouse for the desktop and both laptops)
  • Input Leap and Deskflow (tested 1.27.0) both fail: “No such interface InputCapture”. xdg-desktop-portal-wlr has no InputCapture portal (proposal xdg-desktop-portal-wlr#278).
  • Lan Mouse can receive on labwc, but sending from the labwc machine fails because the pointer lock isn’t held (labwc #3745). I tested elviosak’s patch, ported to 0.9.3, and it works: Lan Mouse capture works on labwc. My results and the diff are on #3745.
15. Raven won’t close when it loses focus
  • Once Raven is open, it stays open: clicking another window, the desktop or the panel doesn’t close it. The only way to close it is pressing Super+A again.
  • On 24.04 (X11) it closed when you clicked away, so this looks like a labwc focus-handling regression.
16. Proton/XWayland games lose keyboard input after using the top panel
  • With Steam running a Proton game (EVE Online), clicking or interacting with anything on the Budgie top panel makes the game stop receiving keyboard input. The mouse still works in the game.
  • Workaround: click any Wayland app (Firefox, for example), then click back into the game, and typing works again.
  • It looks like keyboard focus isn’t handed back to the XWayland window when the panel lets go of focus. It may be the same focus problem as the Budgie Menu (item 2) and Raven (item 15).
I’m assuming this applies to all Steam games potentially under the above situation.
Quality-of-life suggestions
A. Built-in window snapping (Window Shuffler replacement)
Window Shuffler is archived, so I rebuilt the parts I used with labwc regions and keybinds in rc.xml:
  • Regions: left, right, top and bottom halves, plus the four quarters.
  • Desktop: Super+numpad 4/6/8/2 for halves, 7/9/1/3 for quarters, Super+5 to maximize.
  • Laptop-friendly version (no numpad): Super+Ctrl+arrows for halves, Super+Ctrl+Home/PgUp/End/PgDn for quarters. I avoided plain Super+arrows in case Budgie already uses them.
  • Shipping these as defaults (or a toggle in Budgie Desktop Settings) would bring back most of what Shuffler did.
B. Default swaylock config
A default that uses the user’s wallpaper, with the indicator visible and failed attempts shown, instead of the black screen.
C. Login screen improvements
Multi-monitor extend instead of mirror, an option to hide the avatar, quoted wallpaper paths, and the user’s wallpaper as the greeter background.
D. Drop-down terminal
Ctrl+launchesxfce4-terminal --drop-down. On labwc it opened behind other windows until I added a window rule (ToggleAlwaysOnTop` for xfce4-terminal). A default rule or a short how-to would help anyone who used a Quake-style terminal on 24.04.
E. Clipboard bridge for XWayland
Something like item 11 shipped and started by default, or documented, would help anyone gaming under Proton.
F. Show system autostart entries
When Crystal Dock kept starting, the autostart list didn’t show the system-wide entry, so there was nothing to turn off. Showing system entries (with a hide toggle that writes Hidden=true) would have made it a one-click fix.
G. Crystal Dock on every screen
By default the dock follows the current screen only. Unticking “Current screen only” (right-click an app icon) gives a dock on every monitor, which I think most multi-monitor users expect.
H. Brightness fallback
If the helper can’t control a backlight, falling back to brightnessctl and adding the user to the video group would cover laptops like SevenSix.
I. Upgrade notes
A release note on which repos get disabled, how to turn them back on (for example the Mozilla apt repo for Firefox, VSCodium), and how to recover if the desktop doesn’t start after upgrading (the packages from item 12) would save some newer/less technical users some trouble.
What I’ll retest when 10.10.3 arrives
  • Budgie Menu keyboard focus (then remove the fuzzel workaround)
  • Window screenshot shortcut
  • Panel auto-hide (item 1)
  • Raven closing on focus loss (item 15)
  • Primary monitor setting together with my kanshi profile
Thanks again for all the work on this release. Happy to test anything else.
Oops I forgot a recent one from Steam testing added Item #16 to the above.
Took a quick look and we’re good to make this public.
Found an additional bug:
18. “Move window to monitor” shortcuts do nothing. Super+Shift+Left/Right/Up/Down are written to rc.xml by the settings bridge (wm.keybindings/move-to-monitor-*) with an empty action (<action name="" command="" />), so the keys are taken but nothing happens. labwc’s MoveToOutput direction="left|right|up|down" does the job when bound by hand.
Wow - lots of feedback - apologies in advance on the brevity of the responses but can expand if necessary
I wouldn’t call this a bug … but a very recent request to add this as part of the bridge has been made upstream and will form part of 10.10.4
Just an update there is a backport fix I just tested that works for LABWC.
Details can be found at:
