I’ve been facing a rotation bug with Atril and I wanted to see if anyone else is experiencing the same issue or if it’s specific to my Acer Aspire AV15-51 laptop. Here are the details:
When I try to rotate pdf files using the CTRL Left / CTRL Right keyboard shortcuts, they only work the first time.
To return the document to its original position, I have to manually click on ‘Edit > Rotate left / Rotate right’.
I find this to be quite frustrating as I frequently need to rotate pdf files to view maps. It’s making me consider switching back to Evince.
If anyone has any insights or suggestions on how to resolve this issue, I would greatly appreciate it.
Thanks for trying, @fossfreedom!
At the time of the problem, I don’t have any other applications running that might grab them.
I’ve tried other things, and it’s more complicated than that: It happens that the rotation works in both directions, but only for files that I haven’t already tried to rotate with Atril, or for pdfs of a certain type or origin. (?)
