I rolled back (btrfs snapshot) to the moment after 2nd reboot (installed budgie > reboot > enabled additional software sources > updated > reboot). Now I can access Software Sources again. I also managed to add Backports and costales/folder-color ppa, installed calender applet.
The output now (before adding those 2 PPAs) is:
$ sudo apt update && sudo apt upgrade
Hit:1 http://nl.archive.ubuntu.com/ubuntu groovy InRelease
Hit:2 http://security.ubuntu.com/ubuntu groovy-security InRelease
Hit:3 http://nl.archive.ubuntu.com/ubuntu groovy-updates InRelease
Hit:4 http://nl.archive.ubuntu.com/ubuntu groovy-backports InRelease
Hit:5 http://archive.canonical.com/ubuntu groovy InRelease
Reading package lists... Done
Building dependency tree
All packages are up to date.
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
$ cat /etc/*-release
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=20.10
DISTRIB_CODENAME=groovy
DISTRIB_DESCRIPTION="Ubuntu 20.10"
NAME="Ubuntu"
VERSION="20.10 (Groovy Gorilla)"
ID=ubuntu
ID_LIKE=debian
PRETTY_NAME="Ubuntu 20.10"
VERSION_ID="20.10"
HOME_URL="https://www.ubuntu.com/"
SUPPORT_URL="https://help.ubuntu.com/"
BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
VERSION_CODENAME=groovy
UBUNTU_CODENAME=groovy
$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 20.10
Release: 20.10
Codename: groovy
But I also notice on a second laptop (both HP Probook 430 G6, Intel 8th gen), right after my 2nd reboot I get the “System problem detected, do you want to report it now”?
When I click report, nothing happens.
/var/crash
shows this:
I cannot make much of it. I do notice during boot, an error about /swapfile:
Activating swap /swapfile...
Failed to activate swap
The only deviation from a default Budgie install: during setup I selected the main partition on the SSD (there were 2, one is for efi system and the other was ext4) formatted it as BTRFS with mountpoint /
