Hello,
I found Parsing Errors when opening Menu --> Preferences – Menu Editor
I hope the screenshot is able to show the issue, should not be a big issue, as there 2 options:
- Install the 3 missing apps so that the Menu Editor does not complain
- Remove reference of the missing apps from the Menu Editor (Remove package references)
Apps missing: uxterm / xterm / gufw
I hope this helps cleaning it up before the go life.
