Hi, any managed to have cedilla working with language PT for english int. alt keyboard?
Hello there!
Have you ensured proper keyboard configuration during installation? Itâs worth examining the settings to verify the language accuracy. Moreover, itâs possible that your âEnglish Altâ keyboard layout might not be compatible. Consider consulting your computerâs manual for additional guidance.
Update: Iâve come to realize that you can incorporate two keyboard layouts (English Alt and Portuguese Brazilian, in this instance). To make this adjustment, head to the âControl Centerâ settings.
Hi, yes all setâŚthe problem is:
I can type with a brazilian keyboard, ex: ç
but when I use composed keys for cedilha in english keyboard accute + c ( '+c) it goes like 'c
Itâs not really a âproblem,â but rather a keyboard layout issue. When typing in the English keyboard layout, itâs recognized as if youâre using a Portuguese computer keyboard with a different layout. This is why the cedilla is mistyped when using the PT keyboard. My recommendation is to always use the PT layout, especially if youâre unable to use the cedilla with the EN layout.
