I’m learning how to create a Snap, I managed to run a test one earlier, but then switched to an other distro. I’ve come back to UB and found that I can no longer create a Snap. I have install snapd and lxd.
snapcraft cleanbuild
results in
Error: Get http://unix.socket/1.0: dial unix /var/snap/lxd/common/lxd/unix.socket: connect: permission denied
Failed to initialize container: there are either no permissions or the remote ‘local’ does not exist.
Verify the existing remotes by running lxc remote list
. Refer to the documentation at https://linuxcontainers.org/lxd/getting-started-cli.
I think it is failing to download a Linux kernel, am I right and what should I do about it?
chris@desktop:~/SnapWork/test$ lxc remote list
| NAME | URL | PROTOCOL | AUTH TYPE | PUBLIC | STATIC |
| images | https://images.linuxcontainers.org | simplestreams | | YES | NO |
| local (default) | unix:// | lxd | tls | NO | YES |
| ubuntu | https://cloud-images.ubuntu.com/releases | simplestreams | | YES | YES |
| ubuntu-daily | https://cloud-images.ubuntu.com/daily | simplestreams | | YES | YES |
