Hello, i installed ubuntu budgie 18.04 on virtualbox, and it looks very cool. I noticed that there isn’t aero snap, the possibility to place side by side two windows. Is there an option to activate it? thank you
Hi and welcome.
You will need to use the virtualbox option to grab the mouse cursor when you are in the VM. Then when you drag a window left or right towards an edge the window will snap.
Additionally if you press Super + S you have a graphical way to grid windows
