If I want to run docker-compose
yaml files which run a web server and proxy I get Error starting userland proxy: listen tcp 0.0.0.0:8080: bind: address already in use
. In Ubuntu Gnome I usually simply had to disable the builtin nginx
with sudo service nginx stop
. How can I workaround this issue in Ubuntu Budgie?
You’ll need to find the process that’s taken that port - thinks its something like
sudo netstat -pna | grep 8080
or possibly
sudo netstat -nlp | grep 8080
Once you’ve found that then kill the process / stop the service that’s started it.
