I do have 2 hard-disks in my pc. When i open Nautilus and open for example Pictures i do see the pictures i have located in the same map on disk 1. What i like to do is place my pictures in a map at disk 2. How can i make to open the map Pictures and see those on disk 2 instead of disk 1. I mean directly - not first going to other locations - disk 2 - Pictues, but directly.
If yes, you just have to create a “Pictures” folder on disk2 and then create a link in your home that is pointing on this folder:
1st, if you have somme content in it, move/backup your actual “Pictures” folder from your home (so you will be able to move back its content in the new “Pictures” folder pointing on disk2 when it’s ready):
mv ~/Pictures ~/Pictures_old
create the new “Pictures” folder on disk2 (replace <path_to_disk2_mountpoint> by the path where disk2 is mounted):
