Hi, I have installed beta 2. I realised that GPU temp. is high 56 °c compared to win 10 after installed Nvidia driver.
How can I fix it.
56 deg isn’t very high imho. But if it is worrying you please file a bug report on launchpad against the nvidia driver that you are using.
This is so the graphics drivers maintainers are aware of the issue and can suggest stuff. Remember though… proprietary drivers can only be fixed by Nvidia themselves.
Thanks i will report it
