whenever I want to install or uninstall any .deb packages I got this error:
dpkg was interrupted, you must manually run ‘sudo dpkg --configure -a’
when I run this command (sudo dpkg --configure -a) the /etc/default/grub sourcing goes into an unbreakable loop
from terminal:
Processing triggers for linux-image-5.15.0-53-generic (5.15.0-53.59) …
/etc/kernel/postinst.d/dkms:
dkms: running auto installation service for kernel 5.15.0-53-generic
…done.
/etc/kernel/postinst.d/initramfs-tools:
update-initramfs: Generating /boot/initrd.img-5.15.0-53-generic
/etc/kernel/postinst.d/zz-update-grub:
Sourcing file `/etc/default/grub’
output when I run: diff -s /etc/default/grub /usr/share/grub/default/grub`:
6c6
< GRUB_DEFAULT=1GRUB_DEFAULT=0
21,23d20
< $sudo update-grub
37,39d33
