Home Store Blog Development
Same Folder in Budgie Menu Twice
#1
I have two games folders in my Budgie Menu. I have tried menulibre but the second Games menu doesn’t appear in there. Is there a way to get rid of the second games menu?
#2
It shows up in Alacarte however but no option to delete it.
#3
check the files that may be duplicated in ~/.local/share/applications
#4
Thank you the menu directory was in ~/.config/menus/applications-merged. Deleting the file removed it from the menu.
