Hello, I just upgaded from Budgie 21.10 to Budgie 22.04. I wanted to adjust the screen brightness, but i can’t find it no more. On Budgie 21.10 I could adjust thru power screen brightness. On Budgie 22.04 there is no screen brightness control. How can I control the screen brightness?
You should perhaps use the screen brightness controls on your desktop laptop - most laptops control via function keys.
There is also a brightness applet you can add to your panel as well via Menu - Budgie Extras
Also note - I’ve checked with GNOME - they removed the slider that was removed from the power panel.
We unfortunately inherited this change as well.
Thanks a lot, the brightness applet via Budgie extras did the job.
