I wanted to fix Kazam (doesnt save preset directories) there were a bunch of dependency issues that I tried to sort to allow compilation, but in so doing, managed to stop Kazam from working entirely
My guess is I’ll have to reinstall Budgie, but before doing so, if anyone has any idea how to sort it, appreciate. Kazam seems the only (vital) app thats effected.
alistair@alsE590:~$ kazam
/usr/bin/kazam:77: DeprecationWarning: dist() and linux_distribution() functions are deprecated in Python 3.5
dist = platform.linux_distribution()
/usr/local/lib/python3.7/dist-packages/kazam/backend/webcam.py:24: PyGIWarning: GUdev was imported without specifying a version first. Use gi.require_version('GUdev', '1.0') before import to ensure that the right version gets loaded.
from gi.repository import GObject, GUdev
File "/usr/bin/kazam", line 148, in <module>
from kazam.app import KazamApp
File "/usr/local/lib/python3.7/dist-packages/kazam/app.py", line 36, in <module>
from kazam.backend.prefs import *
File "/usr/local/lib/python3.7/dist-packages/kazam/backend/prefs.py", line 566, in <module>
prefs = Prefs()
File "/usr/local/lib/python3.7/dist-packages/kazam/backend/prefs.py", line 142, in __init__
self.config = KazamConfig()
File "/usr/local/lib/python3.7/dist-packages/kazam/backend/config.py", line 87, in __init__
ConfigParser.__init__(self, self.DEFAULTS[0]['keys'])
File "/usr/lib/python3.7/configparser.py", line 638, in __init__
self._read_defaults(defaults)
File "/usr/lib/python3.7/configparser.py", line 1216, in _read_defaults
self.read_dict({self.default_section: defaults})
File "/usr/lib/python3.7/configparser.py", line 753, in read_dict
self.set(section, key, value)
File "/usr/local/lib/python3.7/dist-packages/kazam/backend/config.py", line 149, in set
self.add_section(section)
File "/usr/lib/python3.7/configparser.py", line 1205, in add_section
super().add_section(section)
File "/usr/lib/python3.7/configparser.py", line 655, in add_section
raise ValueError('Invalid section name: %r' % section)
ValueError: Invalid section name: 'DEFAULT'
