Hi everyone. I just upgraded from 24.04 to 26.04 and a bunch of things broke. One is the following:
Pressing ctrl+alt+T doesn’t open the terminal. In Settings > Keyboard > Shortcut > Launcher there is no Open Terminal shortcut, nor anywhere else. I tried creating a custom one, but it doesn’t bind to the ctrl+alt+T shortcut. I can bind it to something like ctrl+alt+H, but if I try to press the ctrl+alt+T combination simply nothing happens, like I pressed nothing. I can’t see the ctrl+alt+T shortcut used for any other command.
ok sounds weird. Not so obvious question - have you logged out and logged in after the first login post the upgrade? Needed to tidy up some stuff.
Please post your ~/.config/budgie-desktop/labwc/rc.xml file - the keyboard shortcut CTRL+ALT+T should be pointing to the terminal defined in gsettings.
do you have the xfce4-terminal available from the menu? If so run it. Then from there type tilix - does that run ok?
If so - you need to update gsettings to point the ctrl+alt+t to run tilix instead of xfce4-terminal.
FYI - the underlying window manager is now labwc and there is a “bridge” process that maps gsettings to the instructions (rc.xml) that labwc expects. So gsettings is the authoriative source for all keybinds.
Do I need to set both to tilix? I don’t know why I have a cinnamon schema, is it normal? Maybe I tried cinnamon in the past (I can’t remember if I did) and remained there?
the cinnamon one comes from the file-manager nemo - so it is fair to update both - I think the cinnamon key is used by nemo when you right click and say “open in terminal / open in root terminal” or something like that.
So “Primary” is what GNOME defines as your CTRL key - usually your left keyboard CTRL.
Yes - you can ignore them - the bridge will take care of the translation.
yes - those packages can be installed via apt i.e. sudo apt install ubuntu-budgie-desktop
I’m a curious person - was your 24.04 install via the Ubuntu Budgie ISO where all of this would have been setup for you - or was your install from another desktop environment, where these meta packages would not have been installed … or some other custom type of installation?
It’s been a while, but I’m pretty sure I installed Budgie from the USB.
OK, I’m installing ubuntu-budgie-desktop but now it tells me that I need to chose the preferred display manager because I have two of them now? Which one I should pick, lightdm or sddm?
Ok, I installed ubuntu-budgie-desktop and set the default terminal to tilix in both the gnome and cinnamon schemas, and now ctrl+alt+t launches the terminal. One problem solved! Thanks.
