Crystal Dock not acknowledging clicks
Hello,
I finally upgraded from 24.04 to 26.04, but I have found that my crystal dock does not work. I saw a previous thread from months ago where the solution was right clicking the crystal dock- but my OS doesn’t seem to acknowledge the crystal dock is there. I am fairly beginner when it comes to linux, so sorry if the answer is simple…
Hi @Sian!
You’re right: normally, you right-click on Crystal Dock to open its settings.
Maybe you could try uninstalling it and then reinstalling it…
Open the terminal (Ctrl+Alt+T) and copy and paste this line to uninstall it and then reboot (just in case):
sudo apt purge crystal-dock && reboot
Then enter this line to reinstall Crystal Dock and check how it behaves at startup — it should start automatically without doing anything:
sudo apt install crystal-dock && reboot
Let us know how it goes.
If crystal dock isnt reponding to clicks it usually because another hidden app is overlaying that.
Double check in your processes if nemo-desktop is running. It shouldnt be because at 26.04 it is not wayland compatible and behaves like a hidden app running above everything else.
