I’m trying to compile vala applets using old ikey 's Vala example applet, but whenver I run a command like “valac --pkg gtk±3.0 ValaExample.vala” it gives me error like
ValaExample.vala:27.48-27.53: error: The symbol `Budgie' could not be found
public class ValaAppletExample : GLib.Object, Budgie.Plugin {
ValaExample.vala:29.12-29.17: error: The symbol `Budgie' could not be found
public Budgie.Applet get_panel_widget(string uuid)
ValaExample.vala:40.27-40.32: error: The symbol `Budgie' could not be found
public class ValaApplet : Budgie.Applet
ValaExample.vala:46.13-46.18: error: The symbol `Budgie' could not be found
unowned Budgie.PopoverManager? manager = null;
ValaExample.vala:109.42-109.47: error: The symbol `Budgie' could not be found
public override void update_popovers(Budgie.PopoverManager? manager)
ValaExample.vala:137.31-137.34: error: The symbol `Peas' could not be found
var objmodule = module as Peas.ObjectModule;
ValaExample.vala:138.46-138.51: error: The symbol `Budgie' could not be found
objmodule.register_extension_type(typeof(Budgie.Plugin), typeof(ValaAppletExample));
Compilation failed: 7 error(s), 0 warning(s)
I’m on Manjaro budgie but I didn’t expect any support from them as their are very less community for budgie ,
I can easily compile other vala codes to C but not budgie-applets , I’m very new to Vala and Budgie-applets please guide me.
Is their other things or other arguments to give to the valac compiler?
also whats the use of MakeFile.am their?
