Default applications
Hello, I came to suggest changing the default applications.
I would like to know if it would be possible to choose xfce4-taskmanager instead of mate-system-monitor.
The reason is that xfce4-taskmanager can be completely in the dark theme, and has a window identification function, where you click on a button and then click on the application you want to find in the list.
Another application that I think could be replaced would be file-roller by engrampa, since engrampa automatically uses GTK themes and its file manager fits better with the design of the Nemo file manager.
