I keep getting errors like these every second or so:
Dec 2 16:26:59 eric-B450-AORUS-M plank.desktop[6386]: ###!!! [Parent][DispatchAsyncMessage] <mark>Error</mark>: PClientManager::Msg_ForgetFutureClientSource Processing <mark>error</mark>: message was deserialized, but the handler returned false (indicating failure)
Does anyone know what is going on?
I have a 3 screen setup and I have seen that plank fails with 3 screens, see for instance https://www.linuxuprising.com/2019/12/a-guide-to-using-plank-dock-on-linux.html. Does the error above have anything to do with this?
My graphics setup is as follows:
$ sudo lshw -class display
*-display
description: VGA compatible controller
product: Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT]
vendor: Advanced Micro Devices, Inc. [AMD/ATI]
physical id: 0
bus info: pci@0000:08:00.0
version: ca
width: 64 bits
clock: 33MHz
capabilities: pm pciexpress msi vga_controller bus_master cap_list rom
configuration: driver=amdgpu latency=0
resources: irq:76 memory:e0000000-efffffff memory:f0000000-f01fffff ioport:e000(size=256) memory:fe500000-fe57ffff memory:c0000-dffff
