How do I make it so that printers on my network are NOT automatically added to my system?
Also, when I tell it to stop a print job, it never does. I am unable to remove a job from the printer. What gives?
In today’s date I have suggestion for you, so for that if you interested with it then just get some reviews and from there you will be very helpful. If you faced any kind of problem with printer then you will just do one thing just go and unnistall the printer driver and after some time again download it and use it properly then you will see the problem will be solved. Also I have epson scanner driver
