Specs:
Core i3 8130U
8GB DDR4 RAM
Intel UHD 620
I just installed Ubuntu Budgie latest version, My cursor is missing. I had a hard time navigating to this page without seeing the cursor. It moves and works but isn’t visible… Any fixes?
Specs:
Core i3 8130U
8GB DDR4 RAM
Intel UHD 620
hmm - that’s intriguing.
So on boot you reach the login screen. Is the cursor visible?
Or does the cursor disappear on login?
What happens if you try a different mouse?
