Upgrade error launchpadcontent net 24.04?
Hi there, I’ve been facing a persistent issue with the launchpadcontent error since my upgrade to 24.04. Is there any way to fix this error?
That means the ppa maintainer has not made a release for noble.
Best untick that source in software update sources (software-properties-gtk)
Thanks, for some reasons it is interfering with an installation so I had to remove it using sudo add-apt-repository --remove ppa:numix/ppa
