I installed Budgie 18.10. One reason I did so was to have the option of raising the volume above 100%. There is no check box for that following the installation. Is there a way to add it? thanks
As per the release notes: “New Raven section in Budgie Desktop Settings. Under this new section, you’re able to show and hide individual widgets as well as enable the ability to raise your volume above 100% in Raven.”
That was it, thanks!! I had to look up where to find the Desktop Settings but that was quick.
