From a dual boot non-efi yeah thats part of the beta testing. No issues.
Specifically you mentioned about it creating a non relevant partition. No idea. Dual booting worked just fine but didnt look to see about additional partitioning.
I can’t speak with authority, but I see the message
“No EFI System partition was found. This system will likely not be able to boot successfully, and the …”
somewhat regularly (both with ubiquity & calamares with Ubuntu & flavor installers), and it’s not a problem if the box is legacy and not using uEFI/Secure-uEFI to boot. There are a number of reasons why the message can occur, and can be influenced by how you wrote the ISO to thumb-drive (I have no experience with ventoy so have no idea how it wrote it)
Thanx all of you for your confirmation and success, now I feel relieved and confident for next step.
@guiverc from my understanding, ventoy seems to write an UEFI-ready media. So as it’s running in that mode that may very well explain why the installer expects / leads to an UEFI installation.
Although partition tables are in mbr/dos… maybe installer doesn’t look that further.
this is after installation, no way to change anything in Budgie Control Settings regarding languages.
By chance here keyboard mapping is correct, azerty / french ( alt ).
During trying in live-usb-session keyboard was in qwerty instead of azerty in most app’s - by chance it was azerty in ubiquity. But no way to change it because of inability in Budgie Control Center.
It’s an old problem in most Ubuntu flavors which does not occur in official Ubuntu.
Other problem encountered : leaving session gets me back as expected on lightdm but resolution broken afterwards, even in regular session.
Unable to check because of resolution issue, I can’t drag windows beyond top panel…
Here I suspect Ubiquity has installed some nvidia driver, but I can’t go back to nouveau from this window :
⋅ says a manually installed driver is in use ( hence my assumption )
⋅ I can’t chose anything else
Have you actually installed the french language via the separate language and region app?
I know all of this works because one tester confirmed by installing dutch and switching between english and dutch and visa-versa. A separate tester confirmed Portuguese install and switching.
You can see here « France » for Formats but actually it never stays in place, at next launch of BCC, it’s America there which comes back.
Also I have removed ( for the moment ) any other language else than French - only basic mandatory English remains.
I did not test long enough to see how or if it affects the system, keyboard mapping is expected azerty + french ( alt ).
BCC version :
ii budgie-control-center 1.0.1-2 amd64 utilities to configure the Budgie desktop
ii budgie-control-center-data 1.0.1-2 all configuration applets for Budgie - data files
