installed 24.04 budgie. somes flatpak ( easyeffects , video downloader ) start slow ( 20 /30 sec) .
using mate ( installed in the same computer) near instant start, no problems.
where is the problem?
Similar issue here.
Suggest try the suggestions to diagnose what the potential issue is
not all flatpak start slow: spotify is ok, easyeffects and videodownloader not ok.
Not a user config problem, because i created a new User with admin privileges, re-installed Flatpaks on that account and no behavoir changes.
on the same system i have installed for test mate and xfce, all flatpak start with 0 delay. problem is only on Budgie 24.04 ; no problem in 22.04 ( 10.8.2 )
no messages when start flatpak from terminal
removed easyeffects ( flatpak ) and installed .deb :
SAME Slow startup on budgie, ok on mate/xfce
Magpie culprit ?
I installed easyeffects from the repositories on 24.04 here - instantly starts up
Similarly - I installed video-downloader from the repositories and it also instantly starts up.
EDIT:
Created a standard user (non administrative) - again no issues.
So this is specific to your user account. What this is I have no idea.
video-downloader from the repositories ? not exist deb repo for this video-downloader
tested with differents account, administrative or not. problem only with budgie, and change user not do anything
Also same problem with snap of video-downloader…
I’m going to try a kernel downgrade
edit: not solve
Also tried on a separate laptop
sudo apt install easyeffects video-downloader
Both worked just fine
So my first laptop is amd graphics and the second is intel graphics.
ok, video-downloader is in repo 24.04
installed but not work , .deb, snap, flatpak.
same easyeffects.
all work on mate, xfce, gnome ( 24.04) , budgie 10.8.2 ( 22.04)
reinstalled os , now work.
