The transition of the Budgie desktop to Wayland comes with a few teething problems that require a bit of tinkering.
Here’s the first in a series of little workarounds I’ve adopted until these inconveniences are resolved.
Hoping you’ll find them useful.
Open the terminal (Ctrl+Alt+T) and copy and paste this line to edit the configuration file of labwc Wayland window compositor:
gedit .config/budgie-desktop/labwc/rc.xml
Add this line just below the <keyboard> tag (line 3): <numlock>on</numlock>
Save and restart.
Note: Even though the numeric keypad is enabled, Lock Keys Indicator applet does not show it.
Pressing a modifier key (Shift, Ctrl, Alt, Alt Gr) will turn on the indicator light.
The issue has been reported on GitHub.
I have not the same behaviour.
When I start, the numeric keypad is not activated, to activate it, I have to press any keylock in order it functions, then on my PC it is the same if I had not modified the rc.xml configuration file.
Anyway I keep it, maybe it will work later on my device ?
No, but it can indeed give that impression depending on the app and/or how it’s launched.
If you launch the terminal with Ctrl+Alt+T, the numeric keypad will be active (and marked as such by Lock Keys Indicator), but you won’t have needed to press NumLock to do so.
