I have tried connect my Android Phone to it but it does not shows anything.
Also tried Another Androids too.
Hi, couple of questions…
which version of Android?
what type of USB connector?
what kind of connection/feature are you trying to use?
I all because I’ll try to replicate. One thing to note, USB c I have found depends on the cables drastically. Not all cables are equal. while the standard is supposed to be able to carry data, power and video, I have found that sometimes certain features work with certain cables. and the reason I am asking about the feature is so that I can try to replicate your specific use case and have a target for success or failure.
Thank you!
How are you connecting phone to the PC? Have you tried to connect it with storage mode enabled on the phone?
I am running Android 8.1 On Mi A1
Using USB C to connect as a MTP
But after connecting the device to laptop it doesn’t display anything about connected device nither does the Android shows any options of UsB configuration.
I have tried Another samsung device too but same goes there.
Before this i i used the ubuntu basic and there the samsung device were displaying perfectecly.
Thanks !
That is the problem i don’t have any options to choose.
The Android doesn’t shows anything.
Nither does the debugging options does anything.
