Hey there,
Connecting my phone as USB-Device shows that in lsusb:
Bus 001 Device 082: ID 2717:ff40 Xiaomi Inc. Mi/Redmi series (MTP)
So the device is recogniced, but the device isn’t mounted in Nemo or the usb-applet shows up.
When logs are needed, plz let me know.
Thx for your help.
mike
Just install go-mtpfs go to nemo computer:/// and the device will show click on, and its mounted.
you could also try to auto-mount details HERE but too much trouble.
Thx AlistairG!
After installing go-mtpfs (with apt install go mtpfs) the phone appeared under computer:// as you mentioned.
Great support. I appreciate your help a lot.
Greets mike
NP, IMHO go-mtpfs should be installed by default then you wouldnt have this type of problem.
