Bluetooth disconnects after few minutes randomly after 21.04 upgrade
As title suggests I have a bluetooth headset which is randomly getting disconnected after few minutes, this only happens after I upgraded to 21.04 yesterday. I’m not sure how to troubleshoot this so any feedback would be nice.
Just some logs just as it disconnected:
Jun 10 10:28:14 laptop-gabriel rtkit-daemon[1213]: Supervising 13 threads of 4 processes of 1 users.
Jun 10 10:28:16 laptop-gabriel rtkit-daemon[1213]: Supervising 13 threads of 4 processes of 1 users.
Jun 10 10:28:21 laptop-gabriel plank.desktop[10392]: [06/10/21, 10:28:21:244] info: [RTM] (TAMHY3N9K) Processed 1 user_invalidated event(s) over 33.04ms
Jun 10 10:28:22 laptop-gabriel plank.desktop[10392]: [06/10/21, 10:28:22:380] info: [API-Q] (TAMHY3N9K) noversion-1623313702.379 Flannel users/info called with reason: flannel-call:users/info
Jun 10 10:28:22 laptop-gabriel plank.desktop[10392]: [06/10/21, 10:28:22:381] info: [API-Q] (TAMHY3N9K) noversion-1623313702.379 Flannel users/info is ENQUEUED
Jun 10 10:28:22 laptop-gabriel plank.desktop[10392]: [06/10/21, 10:28:22:381] info: [API-Q] (TAMHY3N9K) noversion-1623313702.379 Flannel users/info is ACTIVE
Jun 10 10:28:22 laptop-gabriel plank.desktop[10392]: [06/10/21, 10:28:22:646] info: [API-Q] (TAMHY3N9K) noversion-1623313702.379 Flannel users/info is RESOLVED
Jun 10 10:28:23 laptop-gabriel wpa_supplicant[917]: wlp0s20f3: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-59 noise=9999 txrate=270000
Jun 10 10:28:38 laptop-gabriel plank.desktop[10392]: [06/10/21, 10:28:38:297] info: [API-Q] (TAMHY3N9K) noversion-1623313718.288 Flannel users/info called with reason: flannel-call:users/info
Jun 10 10:28:38 laptop-gabriel plank.desktop[10392]: [06/10/21, 10:28:38:298] info: [API-Q] (TAMHY3N9K) noversion-1623313718.288 Flannel users/info is ENQUEUED
Jun 10 10:28:38 laptop-gabriel plank.desktop[10392]: [06/10/21, 10:28:38:299] info: [API-Q] (TAMHY3N9K) noversion-1623313718.288 Flannel users/info is ACTIVE
Jun 10 10:28:38 laptop-gabriel plank.desktop[10392]: [06/10/21, 10:28:38:368] info: [API-Q] (TAMHY3N9K) noversion-1623313718.288 Flannel users/info is RESOLVED
Jun 10 10:28:39 laptop-gabriel wpa_supplicant[917]: wlp0s20f3: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-66 noise=9999 txrate=270000
Jun 10 10:28:40 laptop-gabriel plank.desktop[10392]: [06/10/21, 10:28:40:433] info: [API-Q] (TAMHY3N9K) noversion-1623313720.432 Flannel users/info called with reason: flannel-call:users/info
Jun 10 10:28:40 laptop-gabriel plank.desktop[10392]: [06/10/21, 10:28:40:434] info: [API-Q] (TAMHY3N9K) noversion-1623313720.432 Flannel users/info is ENQUEUED
Jun 10 10:28:40 laptop-gabriel plank.desktop[10392]: [06/10/21, 10:28:40:435] info: [API-Q] (TAMHY3N9K) noversion-1623313720.432 Flannel users/info is ACTIVE
Jun 10 10:28:40 laptop-gabriel plank.desktop[10392]: [06/10/21, 10:28:40:506] info: [API-Q] (TAMHY3N9K) noversion-1623313720.432 Flannel users/info is RESOLVED
Jun 10 10:28:43 laptop-gabriel wpa_supplicant[917]: wlp0s20f3: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-71 noise=9999 txrate=270000
Jun 10 10:28:50 laptop-gabriel wpa_supplicant[917]: wlp0s20f3: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-69 noise=9999 txrate=270000
Jun 10 10:28:51 laptop-gabriel acpid[871]: input device has been disconnected, fd 26
Jun 10 10:28:51 laptop-gabriel dbus-daemon[876]: [system] Rejected send message, 0 matched rules; type="method_return", sender=":1.66" (uid=1000 pid=1348 comm="/usr/bin/pulseaudio --daemonize=no --log-target=jo" label="unconfined") interface="(unset)" member="(unset)" error name="(unset)" requested_reply="0" destination=":1.4" (uid=0 pid=875 comm="/usr/lib/bluetooth/bluetoothd " label="unconfined")
Jun 10 10:28:51 laptop-gabriel gsd-media-keys[1522]: Unable to get default sink
Jun 10 10:28:51 laptop-gabriel budgie-panel[1635]: gvc_mixer_stream_get_volume: assertion 'GVC_IS_MIXER_STREAM (stream)' failed
Jun 10 10:28:51 laptop-gabriel budgie-panel[1635]: gvc_mixer_stream_get_is_muted: assertion 'GVC_IS_MIXER_STREAM (stream)' failed
Jun 10 10:28:51 laptop-gabriel plank.desktop[10392]: [06/10/21, 10:28:51:518] info: [RTM] (TAMHY3N9K) Processed 1 reaction_added event(s) over 55.50ms
Jun 10 10:28:55 laptop-gabriel plank.desktop[10392]: [06/10/21, 10:28:55:376] info: [API-Q] (TAMHY3N9K) noversion-1623313735.375 Flannel users/info called with reason: flannel-call:users/info
Jun 10 10:28:55 laptop-gabriel plank.desktop[10392]: [06/10/21, 10:28:55:376] info: [API-Q] (TAMHY3N9K) noversion-1623313735.375 Flannel users/info is ENQUEUED
Jun 10 10:28:55 laptop-gabriel plank.desktop[10392]: [06/10/21, 10:28:55:377] info: [API-Q] (TAMHY3N9K) noversion-1623313735.375 Flannel users/info is ACTIVE
Jun 10 10:28:55 laptop-gabriel plank.desktop[10392]: [06/10/21, 10:28:55:446] info: [API-Q] (TAMHY3N9K) noversion-1623313735.375 Flannel users/info is RESOLVED
Jun 10 10:28:56 laptop-gabriel wpa_supplicant[917]: wlp0s20f3: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-68 noise=9999 txrate=270000
Have a look at this thread - some thoughts/links and ideas on how to diagnose further.
I have looked at that thread and added the mentioned script in rc.d, but still same issue. Any other help would be appreciated as its annoying as hell.
Do post a question on askubuntu.com and ubuntuforums.org - bluetooth issues are generic to all flavours so the wider community can help here.
Include in your question what you have tried, what you have diagnosed with appropriate logs etc.
thanks for the awesome information.
What worked:
thanks my issue has been fixed.
