Bluetooth connected at startup
Hello!
I disabled bluetooth. When I reboot the machine it goes back on to stay activated.
How do I fix it? I want it to be disabled when I turn on the computer.
v17.10 of UB ?
If so this is a known issue with the bluetooth stack - I understand it has been fixed in 18.04
17.10. Do you recommend installing the 18?
18.04 goes stable in a couple of weeks
I installed it on 18.04. Bluetooth problem continues :confused:
please report a bug to make the ubuntu-devs aware of the issue on 18.04
ubuntu-bug bluez
I have the same issue. I thought that was intentional? If I turn off Bluetooth, it’s on with reboot.
Hmm seems it’s has been a very common issue for a long time.
There doesn’t seem to be one answer though
I was able to workaround this in ubuntu budgie 18.04 by adding rfkill block bluetooth to my /etc/rc.local file.
This gave me the behavior I wanted where when I boot my laptop bluetooth is in airplane mode, but I can enable it from the bluetooth indicator if needed
Note: in my case the rc.local file wasn’t there by default, so I added it with these contents:
#!/bin/sh -e
# rc.local
# This script is executed at the end of each multiuser runlevel.
# Make sure that the script will "exit 0" on success or any other
# value on error.
# In order to enable or disable this script just change the execution
# bits.
# By default this script does nothing.
exit 0
And then made it executable:
sudo chmod 755 /etc/rc.local
I experienced the same problem in Ubuntu 17.10 and in 18.04. The solution I came up with was to mask Bluetooth. It worked for me in both distros.
Try doing this:
sudo systemctl mask bluetooth
That should stop Bluetooth from auto starting.
Presumably the same command substituting “unmask” should restore it?
Unmasking it will allow you to start/stop the service again.
Exactly what I was searching for, thanks !
Strange Bluetooth state is not remembered through session - what’s different regarding bluetooth compared to default ubuntu 18.04 ( where BT state is remembered ) ?
If put in /etc/rc.local does it mean it will set this behavior for all users ?
May that command rfkill block bluetooth be put in « application at startup » for a per user preference ?
I think that way is more convenient than
which demands another sudo command to enable again BT when needed.
I’ve had the same problem and I’ve solved it as follows:
On Desktop Budgie Parameters create a Command Type Autostart App with these commands:
Give it name and description you like (doesn’t matter) and save. Every time you restart your computer your Bluetooth will be disabled.
This is actually even easier than I originally thought… you just need to disable bluetooth within the gnome settings | power section instead of via the bluetooth indicator icon in the system tray.
When I disable it via the gnome settings panel, it stays disabled without any further tweaks needed
Why do you have gnome-settings installed ?
It’s installed by default, budgie is basically an alternate shell running on top of gnome components.
@Coeur-Noir indeed, until budgie makes its own full settings app, gnome settings does most of the work - budgie desktop settings is for theming, panel changing, etc…
