Hi! Expecially the zoom app that communicate with others hangs when turning on Audio. Anyone else have the same problem?
I am using Zoom daily with multiple meetings each day for work. To my knowledge there is no direct conflict. Is the Zoom client up to date?
I belive so. Perhaps my system needs a restart.
But do you know where I can grab the log at where it crashes?
Will it log the error somewhere? IF you know this would help me
soooo much! Thanks
I am not sure (as I have never run into issues. I would go have a look at https://support.zoom.us/hc/en-us
Sorry I do not have a beter answer.
