Budgie-polkit-dialog consumes significant system resources(Ubuntu Budgie 26.04 + labwc)
budgie-polkit-dialog consumes significant system resources even after more than 10 hours of use. VS Code (1.125.1) also uses substantial resources. By late night, with only three windows open, closing VS Code becomes impossible—the click command no longer responds. The only solution is to use `pkill-9 code` to terminate the process..
ubuntu@master:~$ tail -f /var/log/syslog
2026-07-01T22:35:14.875794+08:00 master systemd[1]: systemd-coredump@5-20482-2736811_11114662-0.service: Triggering OnSuccess= dependencies.
2026-07-01T22:35:14.875937+08:00 master systemd[1]: Starting apport-coredump-hook@5-20482-2736811_11114662-0.service...
2026-07-01T22:35:14.879228+08:00 master systemd[1]: tmp-.mount_krita\x2dHBlCfo.mount: Deactivated successfully.
2026-07-01T22:35:15.382307+08:00 master systemd[1]: apport-coredump-hook@5-20482-2736811_11114662-0.service: Deactivated successfully.
2026-07-01T22:35:15.382500+08:00 master systemd[1]: Finished apport-coredump-hook@5-20482-2736811_11114662-0.service.
2026-07-01T22:35:15.382698+08:00 master systemd[1]: apport-coredump-hook@5-20482-2736811_11114662-0.service: Consumed 259ms CPU time over 510ms wall clock time, 152.1M memory peak.
2026-07-01T22:35:17.978736+08:00 master crystal-dock-autostart.desktop[155562]: [21][47523011765]LongTask(60): duration=54ms, container=
2026-07-01T22:36:59.481028+08:00 master nemo[2763681]: Current gtk theme is not known to have nemo support (MacTahoe-Dark) - checking...
2026-07-01T22:36:59.743149+08:00 master nemo[2763681]: Action '90_new-launcher.nemo_action' is missing dependency: cinnamon-desktop-editor
2026-07-01T22:37:00.156949+08:00 master nemo[2763681]: Ignoring thumbnailer with missing binary: '/usr/bin/gdk-pixbuf-thumbnailer'
2026-07-01T22:37:00.157083+08:00 master nemo[2763681]: message repeated 2 times: [ Ignoring thumbnailer with missing binary: '/usr/bin/gdk-pixbuf-thumbnailer']
2026-07-01T22:37:45.359576+08:00 master crystal-dock-autostart.desktop[152526]: 22:37:45.319 › [19f1b53081f][QQ hotUpdate] ----- startAutoUpdate curVersion: 3.2.29-49738 -----
2026-07-01T22:37:45.437587+08:00 master crystal-dock-autostart.desktop[152526]: 22:37:45.437 › [19f1b53081f][QQ hotUpdate] hotUpdateApi getReadyVersionConfig suc
2026-07-01T22:37:45.438635+08:00 master crystal-dock-autostart.desktop[152526]: 22:37:45.438 › [19f1b53081f][QQ hotUpdate] hotUpdateApi getUpdateStatus:  false
2026-07-01T22:37:45.443285+08:00 master crystal-dock-autostart.desktop[152526]: 22:37:45.443 › [19f1b53081f][QQ hotUpdate] hotUpdateApi checkHasMultipleQQ:  false
2026-07-01T22:37:45.444082+08:00 master crystal-dock-autostart.desktop[152526]: 22:37:45.443 › [19f1b53081f][QQ hotUpdate] hotUpdateApi start check  3.2.30-50828  IsOnErrorVersion
2026-07-01T22:37:45.444276+08:00 master crystal-dock-autostart.desktop[152526]: 22:37:45.444 › [19f1b53081f][QQ hotUpdate] hotUpdateApi checkIsOnErrorVersion result: false
2026-07-01T22:37:45.444961+08:00 master crystal-dock-autostart.desktop[152526]: 22:37:45.444 › [19f1b53081f][QQ hotUpdate] [startAutoUpdate] is fullUpdate: true
2026-07-01T22:38:49.940814+08:00 master systemd[1]: Starting sddm-backgrounds-cache.service - Update SDDM user backgrounds cache from AccountsService...
2026-07-01T22:38:49.978148+08:00 master update-sddm-backgrounds-cache[2793788]: SDDM backgrounds cache updated successfully
2026-07-01T22:38:49.978233+08:00 master update-sddm-backgrounds-cache[2793788]: Cache file: /usr/share/sddm/themes/ubuntu-budgie-login/cache/user-backgrounds.json
2026-07-01T22:38:49.978256+08:00 master update-sddm-backgrounds-cache[2793788]: QML file: /usr/share/sddm/themes/ubuntu-budgie-login/components/AccountsService.qml
2026-07-01T22:38:49.982639+08:00 master systemd[1]: sddm-backgrounds-cache.service: Deactivated successfully.
2026-07-01T22:38:49.982952+08:00 master systemd[1]: Finished sddm-backgrounds-cache.service - Update SDDM user backgrounds cache from AccountsService.
2026-07-01T22:39:29.953022+08:00 master dbus-daemon[1489]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.160728' (uid=1000 pid=9070 comm="/usr/bin/mark-shot --tray" label="unconfined")
2026-07-01T22:39:29.957881+08:00 master systemd[1]: Starting systemd-hostnamed.service - Hostname Service...
2026-07-01T22:39:30.072201+08:00 master systemd[1]: Started systemd-hostnamed.service - Hostname Service.
2026-07-01T22:39:30.072579+08:00 master dbus-daemon[1489]: [system] Successfully activated service 'org.freedesktop.hostname1'
2026-07-01T22:39:58.326174+08:00 master systemd[6912]: app-code-1368999.scope: Consumed 28min 40.256s CPU time over 11h 39min 37.212s wall clock time, 3.3G memory peak.
2026-07-01T22:40:00.022528+08:00 master systemd[1]: Starting sysstat-collect.service - system activity accounting tool...
2026-07-01T22:40:00.042673+08:00 master systemd[1]: sysstat-collect.service: Deactivated successfully.
2026-07-01T22:40:00.042944+08:00 master systemd[1]: Finished sysstat-collect.service - system activity accounting tool.
2026-07-01T22:40:00.106212+08:00 master systemd[1]: systemd-hostnamed.service: Deactivated successfully.
2026-07-01T22:43:50.135896+08:00 master systemd[1]: Starting sddm-backgrounds-cache.service - Update SDDM user backgrounds cache from AccountsService...
2026-07-01T22:43:50.180827+08:00 master update-sddm-backgrounds-cache[2873892]: SDDM backgrounds cache updated successfully
2026-07-01T22:43:50.180949+08:00 master update-sddm-backgrounds-cache[2873892]: Cache file: /usr/share/sddm/themes/ubuntu-budgie-login/cache/user-backgrounds.json
2026-07-01T22:43:50.180983+08:00 master update-sddm-backgrounds-cache[2873892]: QML file: /usr/share/sddm/themes/ubuntu-budgie-login/components/AccountsService.qml
2026-07-01T22:43:50.186562+08:00 master systemd[1]: sddm-backgrounds-cache.service: Deactivated successfully.
2026-07-01T22:43:50.186935+08:00 master systemd[1]: Finished sddm-backgrounds-cache.service - Update SDDM user backgrounds cache from AccountsService.
2026-07-01T22:43:53.365530+08:00 master systemd[6912]: Started app-code-2875477.scope.
2026-07-01T22:43:53.701083+08:00 master im-config[2875747]: @ IM_CONFIG_ENTRY='profile' XDG_SESSION_TYPE ='wayland' UID=1000 PID=2875649 PPID=2875477
2026-07-01T22:43:53.705168+08:00 master im-config[2875749]:   GTK_IM_MODULE='fcitx' QT_IM_MODULE='fcitx' CLUTTER_IM_MODULE='' SDL_IM_MODULE='fcitx' XMODIFIERS='@im=fcitx'
2026-07-01T22:43:53.709448+08:00 master im-config[2875752]:   Set IM_CONFIG_CURRENT_DESKTOP <- XDG_CURRENT_DESKTOP='Budgie'
Duplicate of Crystal-Dock (budgie-panel) the bottom panel will disappear and Userspace Out-Of-Memory (OOM) Killer Socket(ubuntu Budgie 26.04)
