Cannot get speakers to work macbook pro 14,1 i5
been troubleshooting with chat gpt all day, have tried downgrading and upgrading kernel. have tried SOF software. in pavucontrol shows dummy audio, when i go to change the profile it says OFF, clicking the list of other options only shows digital HDMI’s, nothing analog. every time i try something and reboot, my wifi stops working. would really like to use my speakers and not have to use headphones, please help me.
summary of what i have tried today from chat gpt
MacBookPro14,1 Internal Speakers on Ubuntu Budgie – Troubleshooting Summary
Hardware: MacBookPro14,1
OS: Ubuntu Budgie
Current Kernel: 6.16.5 (custom / latest installed)
Issue: Internal speakers show “Dummy Output” in PulseAudio; only HDMI audio devices are detected.
What Has Been Tried So Far
Checking audio hardware
lspci | grep -i audio → Intel Corporation Sunrise Point-LP HD Audio (rev 21)
cat /proc/asound/cards → only HDA Intel PCH, HDMI devices listed, no analog speakers detected.
Module management
Attempted to reload snd_hda_intel module:
sudo modprobe -r snd_hda_intel
sudo modprobe snd_hda_intel
→ Failed (module in use).
Tried adding options snd-hda-intel model=mbp101 to /etc/modprobe.d/alsa-base.conf → no change; profile in PulseAudio still “Off”.
PulseAudio troubleshooting
Installed pulseaudio and pavucontrol.
Verified configuration → analog output options unavailable.
Restarted PulseAudio: pulseaudio -k && pulseaudio --start.
SOF / firmware attempts
Tried installing sof-firmware via apt → package not found for 6.16.5 kernel.
Attempted manual download/installation of SOF firmware → resulted in system reboot and Wi-Fi stopped working.
Learned that 6.16.5 kernel does not have full support for MacBookPro14,1 SOF audio modules (snd_sof, snd_soc_skl missing).
Custom driver compilation
Cloned snd_hda_macbookpro repository and tried to make and make install → modules installed but internal speakers still not detected.
Live USB testing
Booted Ubuntu Budgie live USB (kernel 6.14.0-27).
Tried installing SOF firmware and removing snd-hda-intel model=mbp101 override in live session.
Goal: confirm if internal speakers work in a supported kernel without touching the installed system.
Outcome pending: not fully tested yet in live session.
Other attempted fixes
Checked PulseAudio and ALSA configuration (pavucontrol, /proc/asound/, /etc/modprobe.d/).
Tried removing old configuration files, rebooting, reinstalling modules.
Still only HDMI devices detected; analog output remains unavailable.
Current Understanding
Kernel 6.16.5 lacks proper SOF audio support for MacBookPro14,1, which is why internal speakers never appear.
Installing SOF firmware on 6.16.5 breaks Wi-Fi.
Solution path: use a supported kernel (e.g., 6.14 LTS HWE) that has SOF support, confirm speakers work in a live session, then safely install alongside 6.16.5 on the installed system.
Questions / Next Steps for Forum
Can internal speakers on MacBookPro14,1 work on kernel 6.16.5, or is 6.14/6.15 required?
Are there any patches or DKMS modules to enable SOF audio on 6.16.5 safely?
Best practice to test speakers on live USB without affecting Wi-Fi.
Recommended method to dual-boot kernels for audio vs Wi-Fi functionality.
This really deserves a larger audience. It can be answered by the wider ubuntu community since it appears to be kernel related.
Try also discourse.ubuntu.com as well as askubuntu.com
