Little problem with my Ubuntu Budgie Desktop (19.04). The desktop font (I tried Noto and Ubuntu) is too big. I know about the location where I can change the fonts in the preferences and everything else is working fine - but the desktop stays unaffected (also after restart).
Any propositions?
The desktop on 19.04 is handled by nemo-desktop.
To change the various settings of nemo-desktop you need to delve into dconf (gsettings) using dconf-editor
Dconf did the trick. Thank you very much!
Changing the font from the Budgie Desktop Setting was very convenient. No chance to get it back into?
sure - there is a chance … just needs a tweak and a tuck on the existing budgie-desktop-settings code to enable specifying “no desktop handler”/“Nautilus 3.26”/“Nemo”
Couple of screenshots of work in progress
Desktop Icons via Nemo
Desktop icons via DesktopFolder
Needs more testing before making a PR upstream.
