Difficulties compiling Vala
I am trying out Vala with the intent to maybe develop an applet for UB.
Everything is still at a very initial state and I am working myself though the vala tuts here.
I am using VS Code (don’t know if this is the best tool), and compiling works ok when I use GTK2 with the command
valac --pkg gtk+-2.0 gtk-hello.vala
But when use GTK3
valac --pkg gtk+-3.0 gtk-hello.vala
I am getting the error
gtk-hello.vala.c:7:10: fatal error: gtk/gtk.h: No such file or directory #include <gtk/gtk.h> #include <gtk/gtk.h>
The vala documentation on the net is scarce, and what I found to solve the issue was installing the libgtk-3-dev library, with:
sudo apt-get install libgtk3.0-dev
But that returns:
Package libgtk-3-dev is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or is only available from another source
E: Package 'libgtk-3-dev' has no installation candidate
How do I solve this?
Have you enabled “sources” in the updater-settings? Dont forget to fully update after enabling
oops - noticed a slight typo in the package name
sudo apt install libgtk-3-dev
Tried that package name with the same result :
 Reading package lists... Done
 Building dependency tree
I’m having trouble to find that option …
its on the Ubuntu Software tab.
weird!
Can I please see the full output of:
sudo apt update
sudo apt upgrade
Sure, thanks for your help :
sudo apt update
Ign:1 http://dl.google.com/linux/chrome/deb stable InRelease
Hit:2 http://ppa.launchpad.net/oguzhaninan/stacer/ubuntu disco InRelease
Hit:3 http://archive.ubuntu.com/ubuntu disco InRelease
Hit:4 http://dl.google.com/linux/chrome/deb stable Release
Hit:5 http://shop.softmaker.com/repo/apt wheezy InRelease
Hit:6 http://archive.ubuntu.com/ubuntu disco-updates InRelease
Hit:7 http://ppa.launchpad.net/tista/plata-theme/ubuntu disco InRelease
Hit:8 http://archive.ubuntu.com/ubuntu disco-backports InRelease
Hit:9 https://deb.torproject.org/torproject.org bionic InRelease
Hit:10 http://archive.ubuntu.com/ubuntu disco-security InRelease
Hit:12 http://ppa.launchpad.net/ubuntubudgie-dev/desktop-icons/ubuntu disco InRelease
Hit:13 http://ppa.launchpad.net/ubuntubudgie/backports/ubuntu disco InRelease
Hit:14 http://ppa.launchpad.net/vala-team/ppa/ubuntu disco InRelease
Reading package lists… Done
1 package can be upgraded. Run ‘apt list --upgradable’ to see it.
apt list --upgradable -a
Listing… Done
libreoffice-style-sifr/disco-updates,disco-updates,disco-security,disco-security 1:6.2.6-0ubuntu0.19.04.1 all [upgradable from: 1:6.2.5-0ubuntu0.19.04.1]
N: There are 2 additional versions. Please use the ‘-a’ switch to see them.
rainer@rainer:~$ apt list --upgradable -a
Listing… Done
libreoffice-style-sifr/now 1:6.2.5-0ubuntu0.19.04.1 all [installed,upgradable to: 1:6.2.6-0ubuntu0.19.04.1]
libreoffice-style-sifr/disco,disco 1:6.2.2-0ubuntu2 all
sudo apt upgrade
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
odd - have you got the main repo ticked on the software & updates tab?
That’s how the tab looks now : the top box (main) wasn’t checked.
I don’t know if I unchecked the box accidentally, or if it was unchecked from the beginning.
After checking “main”, the system went through a whole lot of updates and upgrades, and installed
libgtk-3-dev successfully.
Now vala compiles GTK3 without a problem.
Thanks for your swift help, David.
