I am having trouble with scaling issues for certain programs.
For example I use R for statistics, and when plot windows are created (which I believe uses X11), they are incredibly small on my 3200x1800 display, even when I’m useing 200% scaling.
If I switch to a lower resolution for the monitor (1920x1080 with 100% scaling), the plot windows are a readable size, but everything else looks quite blurry and lacks clarity.
Is there a way to enforce the 200% scaling for these programs, or is there a way that I can preserve the sharpness when applying lower resolutions to the entire screen?
[Im using Ubuntu Budgie 20.04 on a Dell XPS 13 9343]
