Flat Remix icons, making them look nicer?
Does anyone know why Flat Remix looks so bad in Budgie’s top panel, but fine on other desktops? The icons are unevenly spaced out, and vary in size.
Same for Arc icons. I usually have to pad here and there with spacers which still doesn’t give a complete even look when all is said and done.
Flat Remix icons are designed with the Gnome Shell and KDE in mind and were probably not even tested on Budgie. This would be a question or request for the developer.
