How do I download the daily build?
Hi, How do you install daily build ? You use a virtual machine to refresh daily or something else. I would love to contribute but I need some guidance.
I use zsync to download the daily from here
http://cdimage.ubuntu.com/ubuntu-budgie/daily-live/current/
sudo apt install zsync
mkdir ~/Downloads/jammy
cd ~/Downloads/jammy
zsync http://cdimage.ubuntu.com/ubuntu-budgie/daily-live/current/jammy-desktop-amd64.iso.zsync
This will download the iso to a jammy subfolder in your Downloads folder.
Then when you want to get the latest - say next week - then just make sure you are in that subfolder and rerun the zsync command again.
zsync just downloads differences thus saves your bandwidth.
I use a combination of spare hardware and a virtualbox virtual machine to install the iso.
I created a partition on my older laptop and after installation I update daily.I rarely have broken installations but it does happen during the development cycle. Don’t use a development release for your daily driver and familiarize yourself with bug reporting.
I am getting following error while starting the VM.
If you are using virtualbox installed from the repos then you should ubuntu-bug the issue.
If this is virtualbox installed from the oracle repo then you need to jump onto the oracle forums.
