Quick question, if I install the latest daily iso (dated 10/16/2018), will I have to do another install after final release is done? Or can I simply do apt-get update && apt-get upgrade and basically have the same system as if I installed the final release version?
A simple apt update is all that is required.
Hope that helps.
