How to create a memory snapshot in QEMU KVM?
ENV: Ubuntu budgie 25.04 + qemu kvm
The main purpose is to save the running Win11 virtual machine, and the memory snapshot of different software displayed at different positions on the screen. I used the following command but failed. If I modify virsh edit win11, the virtual machine cannot start.
ubuntu@web:~$ virsh snapshot-create-as   --domain win11   --name win11-full-running   --description "Full snapshot with memory state"
error: Operation not supported: internal snapshots of a VM with pflash based firmware require QCOW2 nvram format
ubuntu@web:~$
ubuntu@web:~$ virsh snapshot-create-as \
  --domain win11 \
  --name win11-memory-save \
  --atomic
ubuntu@web:~$
ubuntu@web:~$ sudo qemu-img convert -f raw -O qcow2 /var/lib/libvirt/qemu/nvram/win11_VARS.fd /var/lib/libvirt/qemu/nvram/win11_VARS.qcow2
ubuntu@web:~$ virsh edit win11
<nvram file='/var/lib/libvirt/qemu/nvram/win11_VARS.fd' format='qcow2'>
Start the Windows11 virtual machine
 internal error: process exited while connecting to monitor: 2025-06-03T14:50:09.654344Z qemu-system-x86_64: -blockdev {"node-name":"libvirt-pflash1-format","read-only":false,"driver":"qcow2","file":"libvirt-pflash1-storage","backing":null}: Image is not in qcow2 format
  File "/usr/share/virt-manager/virtManager/asyncjob.py", line 71, in cb_wrapper
    callback(asyncjob, *args, **kwargs)
  File "/usr/share/virt-manager/virtManager/asyncjob.py", line 107, in tmpcb
    callback(*args, **kwargs)
  File "/usr/share/virt-manager/virtManager/object/libvirtobject.py", line 57, in newfn
    ret = fn(self, *args, **kwargs)
  File "/usr/share/virt-manager/virtManager/object/domain.py", line 1384, in startup
    self._backend.create()
  File "/usr/lib/python3/dist-packages/libvirt.py", line 1379, in create
    raise libvirtError('virDomainCreate() failed')
libvirt.libvirtError: internal error: process exited while connecting to monitor: 2025-06-03T14:50:09.654344Z qemu-system-x86_64: -blockdev {"node-name":"libvirt-pflash1-format","read-only":false,"driver":"qcow2","file":"libvirt-pflash1-storage","backing":null}: Image is not in qcow2 format
Looks like this capability has been deliberately disabled from working
virtualbox7.1.8 can achieve memory snapshots, but unfortunately, it does not support the 6.14 kernel.
The message refers to internal snapshots - did you read about external qemu snapshots - a little more work, but these should work.
Link copied-pasted here
