Okay, I do not know if it should work like this, because the xp-pen driver does not have a maximize the window button, but I will ask anyway. Is this how it should work, or can it be fixed? I use Budgie Pixel Saver and Global Menu
What version of ubuntu budgie are you using?
22.04.2 LTS with all updates
ok - you need to get busy with a bit of command line trickery.
first install dconf-editor
Run dconf-editor and navigate to net.milgar.budgie-pixel-saver.blacklist
Look at the values of the key blacklist-apps
Next type the following in a terminal
xprop
The cursor will change - click on the xp-pen window
In the terminal look for the WM_CLASS value for this window. This is the value you need to append to the blacklist-apps - everything
e.g. if WM_CLASS is “FRED_BLOGS” then
['Firefox', 'TelegramDesktop', 'Ulauncher', 'FRED_BLOGS']
logout and login
Thanks for the feedback, it helped ![]()
