Can you make a popup window, when keyboard layout is changing…
Similar how in Ubuntu Gnome Desktop is…
There is an inbuilt budgie-applet “keyboard layout” that you can add to your panel and you will see via the panel when the keyboard changes
But given that keyboard switching is part of budgie-desktop itself, any enhancements such as an option to add a OSD type display or a notification when keyboard switching occurs should be through the upstream issue tracker
Thanks for answer.
Yes, I know, that there is a budgie-applet for keyboard layout. I’m using this.
But, my problem is, that I’m using autohide option for top panel, and I’m using 4 languages.
