Night Light is not working on my machine
I did fresh install of Ubuntu Budgie 18.04 just minutes ago and noticed that Night Light is not working. Any solutions to this problem?
Try to go into the full menu configuration. Change to manual mode, low the temperature then back it to the normal and see if worked.
I was having the same problem, but after going into the configurations pannel, the issue was solved and the shortcut is working
Thanks it worked! :slight_smile:
Happy that it worked for you!
