No sound notification!
Hello all :slight_smile:
Sound is activate, tested, right, left.
Notification is activate with sound but only message in windows notify me
No sound, no system sound nottification or software like “Konversation”.
Can you help me ?
Thx.
Phil
Hi and welcome.
What version of ubuntu budgie are you using - 20.04?
Please post a picture of the setting you are referring to. Thx
lsb_release -a
No LSB modules are available.
Distributor ID:	Ubuntu
Description:	Ubuntu 22.04 LTS
Release:	22.04
Codename:	jammy
Thanks a lot !
Raised the issue upstream - not sure what we do/don’t support in this area What are our supported Notification options · Issue #117 · BuddiesOfBudgie/budgie-desktop · GitHub
@blitzeur : do you expect the notification to make a sound when it pops-up on screen ?
That would …sound very annoying to me - maybe are there options / settings for (dis)abling it ?
Hello and the @fossfreedom and @Coeur-Noir
@Coeur-Noir Yes but how “able it” ? (really)
Thx :slight_smile:
Don’t know how to enable it - hence the upstream question posted by @fossfreedom
I think notifications in Budgie are silent on purpose.
I would agree, because having been using Windows, it is very annoying how notifications would default to sound and banner, There are pretty much no notifications that I really need the sound for.
So upstreams view is that notification sounds is not yet implemented but could be on the future.
So yes there is a mismatch here from a GUI point of view which may be rectified in the future. Lets wait and see.
