Extremely nit-picky issue, but perhaps I’m overlooking a simple fix…
Since upgrading to 22.04, my notifications (which I’ve set to appear bottom-right) are now appearing a distance up the screen, instead of neatly in the bottom right corner like before.
I can’t see any other settings other than the one to pick which corner they’re on.
Any ideas?
I would raise this on the upstream tracker so that has more visibility.
Sure, thanks, I will do this.
In the meantime, if anyone else notices this and finds the fix, let me know!
Please raise a bug report on launchpad and we will first verify that the upstream fix is suitable for a backport to 22.04 before going through the stable release process.
ubuntu-bug budgie-desktop
Please note that you can now test the proposed upstream fixes by using this daily PPA https://launchpad.net/~ubuntubudgie-dev/+archive/ubuntu/budgie-desktop-test
Let me how you get on.
Note we need that launchpad bug report together with your help to release this officially.
