is there a way to make notifications stay a little longer on screen ?
( and eventually change their position… )
Did not see such settings in dconf editor.
It isn’t difficult to implement. Just really a question if where to put the minimum maximum second scroll fields on the gui
In settings / notifications ? But there it means it’s a gnome thing…
Or through a notification applet, to create - something like https://extensions.gnome.org/extension/708/panel-osd/ ?
Or somewhere into Raven, in notifications tab ?
budgie-desktop v10.5 notification handling has been mostly now been backported in a SRU release of budgie-desktop for v18.04
Hovering over a notification stops the notification disappearing.
Notifications are no longer huge - correctly truncated.
