Just installed U Budgie yesterday (latest version) how do i fix this theme snaps that keeps popping up?
Also how come is notification text truncated so you cant see all the text?
When you see the notification popup just click the yes / no button. Yes its a bug in thay snap integration where a no answer actually installs the snap.
Thank you. Quite annoying bug, can it be squashed?
Also in the notification widget in Raven. Why cant i expand a notification and see the whole text of the notification? The text is truncated.
Well i raised this many months ago on the canonical github tracker but no movement. Guess it will need to be debugged and resolved by someone who is interested.
The truncation of the header part of the notification is needed to prevent the text messing up raven width
