These are just some ideas on our focus for 27.04. Feel free to ask questions, raise points of interest, offers for help etc.
Add kimageformat6-plugins as a recommendation to budgie-artwork - this will open up JXL, JPEG2000 and other image types for the SDDM wallpaper→ doneRelated - package budgie-backgrounds v4.1 from upstream - this now ships its backgrounds in JXL format.→ done- Improve accessibility - add wvkbd as the on-screen keyboard, update budgie-control-center config to ensure on-screen accessibility is a definable option.
Budgie 10.10.3 makes changes to the default menu applet, and budgie-extras applications-menu has similar changes. Package.→ Done- Need to offer up tweaks to key themes supported in budgie-welcome otherwise these applets above appear with a transparent background
- budgie-welcome ASTRO edition - this is a really exciting change for welcome. Completely revamped by Nikola. We need to plugin the python bits around and to iteratively test this before rolling out to all supported budgie versions.
- Replace SDDM X11 with SDDM + Wayland Compositor (e.g. Cage). This will make our distro end-to-end wayland. → see below for an example.
- Budgie 10.10.x - respond to issues raised on buddiesofbudgie and help to resolve.
Package 10.10.4 and all related packages for 27.04 in a timely release manner→ donePackage 10.10.4 and all related packages for Debian Forky→ Now in DebianSpecifically package v10.10.3 budgie-desktop-view which allows icons to be moved throughout the desktop.→ Done- stretch goal - create a Qt based slickSDDM settings app - great learning experience for Qt 6 base development
- Fix up QuickChar for wayland compatibility
- Fix up budgie-browser-profile-launcher for wayland compatibility
- Update theme and icon packages as and when released by their upstream. Consider backporting to older supported UB versions
- Rework budgie-sway-session for UB - upload to development PPA for testing.
- Package budgie-sway-session for Debian to allow install on 26.10
- Revisit nemo-desktop again - linuxmint upstream have made changes to make nemo-desktop fully wayland compatible. Lets see if its suitable for budgie.
- it appears the next version of gthumb - our image viewer and part time image editor - will be libadwaita based. Look to substitute it.
- sadly “drawing” hasn’t seen any meaningful progress over the last couple of years … so again - may want to consider options in this space.
- Work out best way to make our Raspberry Pi image more automated - current issues mainly around GNOME-Shell finding its way onto our image.
- Revamp the seeds. Look for areas to cleanup. Example is the use of !syntax for attempting to block germinate from pulling in packages. the blacklist file should now be renamed blocklist and should be the primary source for blocking packages.
- Check and if necessary fix the plymouth text theme (budgie-artwork/debian at master · UbuntuBudgie/budgie-artwork · GitHub) - the triggers/postrm etc make reference to lsb_release - this has been changed to os_release (I think) in 26.10 so we need to ensure the text theme still functions as expected.
- Resolve raised launchpad issues:
Bug #2172658 “Stop recommending gnome-accessibility-themes” : Bugs : xubuntu-meta package : Ubuntu→ done
Bug #2173094 “Please move Depends: network-manager-gnome to netw...” : Bugs : ubuntu-budgie-meta package : Ubuntu→ done - Move budgie-welcome onto core26 which is the recommended version for resolute.
- Mull over adding lightning-matrix to our distro - looks to be an exciting rust based Qt matrix chat app. Thoughts?
- Mull over replacing xfce4-terminal with ghostty - other changes would need to update the bridge labwc example file to CTRL ALT T this terminal and also budgie-desktop-view to open with terminal option
Suggested UI fixes:
- Would also be useful to make sddm pick up resolution/scaling algo. Login screen widgets are teeny tiny on 4k screen. Currently have to set the config in 50-ubuntubudgie.conf - for info on KDE they achieve this via System Settings > Colors & Themes > Login Screen (SDDM) > Apply Plasma Settings - this makes various settings in SDDM use the user desktop settings at that point of choosing the option.
[General]
InputMethod=qtvirtualkeyboard
GreeterEnvironment=QML2_IMPORT_PATH=/usr/share/sddm/themes/ubuntu-budgie-login/components/,QT_IM_MODULE=qtvirtualkeyboard,QT_SCREEN_SCALE_FACTORS=1.5
The schedule for 27.04 is Ubuntu Tenacious T-Rex Release Schedule - Ubuntu release notes
