Slick-greeter - how to center login credentials?
Would like to center the username and password fields in the login screen. Assuming I’d want to modify 50-slick-greeter.conf or slick-greeter.conf. However, I’m not certain what syntax to use.
Thanks for any input.
GM
Slick greeter does not have that capability.
I am sure upstream would appreciate a code patch to make it happen but for the moment you will need to accept it as is or choose another greeter such as lightdm-gtk-greeter.
Ah … i see there is a pull request upstream that should resolve this.
It hasnt been reviewed nor merged yet though
Ok, thanks. It’s not a priority really, just thought I’d inquire. I’ll wait and see.
GM
