Aliases are really great!
Open the terminal (Ctrl Alt t) and enter this line to edit (or create) the alias file:
gedit .bash_aliases -
Copy and paste this line:
alias gs='_gs() { gedit 2> /dev/null admin://"$1" ;}; _gs' # Edit a file with “sudo” permissions -
Save, close the editor and the terminal.
Open the terminal again and type “gs” (as in “Gedit Sudo”) followed by the path to the file you want to edit.
For example:gs /etc/fstab
What’s more, the terminal won’t complain because you’re launching a graphical application with superuser privileges!
